hello guys!!/ Adding OD??
Old Dec 22, 2005 | 10:55 AM
manolo0908's Avatar
manolo0908
Question hello guys!!/ Adding OD??
I am very excited to be a member of the ford Forum team and I hope you can help me.
I have a F-250 Ranger (5.8 liters enginee) 1978 and I am wondering if I can add an overdrive without hurting the differential gear. I need to do so for two main reasons: I want that the enginee works in a lower range of rpm and I am riding about 60-70 miles per day and the gas today is very expensive!!
If you have any suggestions they would be very welcome.
Thank you!!
manolo0908
Old Dec 22, 2005 | 12:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Dec 22, 2005 | 12:24 PM
1975Ford's Avatar
1975Ford
you can buy a gear vendor at gearvendors.com.
Conversion should be smoother using the ZF-5 speed transmission and uses a clutch fork to engage the clutch.
Here some useful sites.
https://www.ford-trucks.com/forums/s...d.php?t=435162
https://www.ford-trucks.com/user_gal...&albumid=11298
Old Dec 22, 2005 | 01:49 PM
73Custom's Avatar
73Custom
It won't hurt the differential at all. Is this a 2wd or 4x4? auto or 4spd? You have several options for a overdrive. An external overdrive like 1975Ford mentioned or swapping in a overdrive tranny out of a newer pickup.
Marty
Old Dec 22, 2005 | 06:45 PM
manolo0908's Avatar
manolo0908
thank you very much guys!! you are very kind. i will check the links you sent me and them, if any cuestions arise, i will contact you again.
merry christmas and a happy new year for all of you!!
ps/ my truck is not a 2wd, nither a 4X4. it has traction in one wheel only (is this auto or 4 spd?)
