Bronco II Ford Bronco II
Tire Sizes
Old Dec 22, 2005 | 07:18 AM
HPjunky's Avatar
HPjunky
Tire Sizes
Hey guys new here to the site and new to owning a '90 Bronco II. I been looking into getting some new tires for mine, Bridgestone Dueler M/T is what I am looking to get. I know the little trucks call for 205/75/15 tires but I am looking to get 235/75/15. Currently there is no lift and its running the stock alum. rims. This is an Eddie Bauer edition if it makes a difference on the rims. Thanks in advance for any advise on tire sizes.
Old Dec 22, 2005 | 07:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 22, 2005 | 10:57 AM
87ford4x4inline6's Avatar
87ford4x4inline6
I have a 89 BII EB and run 235/70/15 and have no problem with them. I belive you can run up to a 30x9.50 with any lift. That will be what I buy next.
Old Dec 22, 2005 | 11:27 AM
mrshorty's Avatar
mrshorty
The largest tire you can run without any rubbing will be somewhat dependent on the indivdual characteristics of your truck, but most of the time the answer is 235/75R15. My 235/75R15's will rub the swaybar at full steering lock (if I have the swaybar installed), but otherwise aren't a problem. Engineering data for the tires I've looked at suggest that there's less than 1/2 inch difference in the diameter of a 235/75R15 and 30/9.5R15, so I expect the latter will also fit pretty well in a BII. I've tried the 31/10.5R15's from my Explorer on my BII, and they rub as the suspension flexes and while turning, but I'm sure there are those out there who could tolerate it. One on this forum recently even claimed to have put 31's on his stock BII (no lift or anything) without rubbing.
