Differental broke! Busted cover
Old Dec 22, 2005 | 12:12 AM
Talyn's Avatar
Talyn
I posted this in the apropriate thread, but wanted to link in here, cause most people corrouse in this forum instead of the appropriate one.
Pluss i really need to get this project somewhere in 2 days with little cash as possibal.
https://www.ford-trucks.com/forums/s...68#post3235168
Thanks guys!
and gals.
Old Dec 22, 2005 | 10:13 AM
mmbintn's Avatar
mmbintn
Assuming you can get the screw that holds the pin out and nothing else is wrong with the rear end then you can go to for and buy a new pin and put back together. If the pin is in there for good, you may be able to to use and easyout and get it still but if not, then a carrier replacement is whats next. As for oil I have always used 80-90 or 75-90 oil and fill it till it starts to run out the hole.
