#1 plug
Old Dec 21, 2005 | 10:04 PM
rbcyouthdude's Avatar
rbcyouthdude
Smile #1 plug
Which plug is the #1 on a 351M? I need to set the timng.
Michael
Old Dec 21, 2005 | 10:52 PM
53fatfndr's Avatar
53fatfndr
As you are facing the engine, it will be the first plug on the left side of the engine. Also, there might be a "1" on your distributor cap, it should be approximately in the 1-2 o'clock position as you are facing the engine and looking down on the cap. You could trace that plug wire to the #1 spark plug too if you want.
Old Dec 22, 2005 | 10:50 AM
Bill_Beyer's Avatar
Bill_Beyer
A good trick to remember which is #1: on all American V8 engines the cylinder banks are always offset. #1 cylinder will be the first cylinder on the forward most bank.
Old Dec 28, 2005 | 01:33 PM
dlbelton's Avatar
dlbelton
Michael
It's the front cylinder on the driver's side on all ford V8's.
Old Dec 28, 2005 | 04:27 PM
firstonraceday's Avatar
firstonraceday
No, 53fatfndr had it correct, front cylinder on the passenger side for the 351M.
Old Dec 28, 2005 | 07:53 PM
dlbelton's Avatar
dlbelton
yep... passenger side is correct... I was thinking about something else and had a massive brain fart...
