Aerostar Ford Aerostar
Urgent Question
Old Dec 21, 2005 | 03:24 PM
Ray_N's Avatar
Ray_N
Urgent Question
Is the cover on top of the cluster seperate from the cluster? or is the cluster and it's cover all one piece?
Old Dec 21, 2005 | 03:54 PM
cookkd's Avatar
cookkd
The cover is a separate piece. Two screws below and to the left and right of the steering wheel. Three screws on the front edge close to the windshield. Once they are out tap it upward right behind the steering wheel and in between the pods that hold the light switch and a/c heat controls. There are two plastic pins that fit into a slot tightly. That will separate the cover from the cluster.....
Old Dec 21, 2005 | 03:58 PM
93nighthawk's Avatar
93nighthawk
While removing it from the dash, it is one piece, after removal, you can tear the instrument cluster apart if needed.
Is that what you needed to kow? Or are you talking about the trim piece?
Old Dec 21, 2005 | 03:59 PM
Ray_N's Avatar
Ray_N
Yap
thanks dudes.
Old Dec 21, 2005 | 04:10 PM
Ray_N's Avatar
Ray_N
What is the dirtiest and quickest way of getting it out?
Old Dec 21, 2005 | 06:27 PM
cookkd's Avatar
cookkd
Unscrew the fasteners and pop it straight up
Old Dec 22, 2005 | 08:20 AM
Pablo-UA's Avatar
Pablo-UA
Use short screw driver and be careful, do not damage a windshield.
