Expy dies when cold...
Old Dec 21, 2005 | 10:39 AM
kccollier's Avatar
kccollier
Hey folks, I have a 2000 Expedition that has started to have a weird problem. If the engine is cold and you start the truck, it idles so low that it will just die. The motor will stay running if you put your foot on the gas and keep the rpms up. Once the engine is warmed up a little, it will still idle pretty low (around 500 rpms), but will stay running. Now, the "service engine soon" light is on so I went to Autozone and had the code read. It said "Idle Speed Controller." The guy at Autozone said it could be several different things from the computer to a sensor. From reading some forums online, I have seen that this problem can be cause by the Idle Air Control Valve. Are these two related? Do you think this is what the issue is? If not, what do you think is causing this trouble?
Thanks,
Kyle
Old Dec 21, 2005 | 10:56 AM
l-m tech's Avatar
l-m tech
usually the idle air control valve can be cleaned for you r starting and idle problem but if it is setting a code you have to replace it.dirty iac's dont produce a code or turn on the cel
Old Dec 21, 2005 | 11:18 AM
kccollier's Avatar
kccollier
So you agree that it is the Idle Air Control Valve? That is what the repair manual points to aswell, so I will pick up a new one a give it a shot. Thanks!
Old Dec 21, 2005 | 12:47 PM
dmanzo's Avatar
dmanzo
I had the same problem. I just pulled the IAC and gave it a good cleaning, now it works like a charm.
Old Dec 22, 2005 | 09:24 AM
projectSHO89's Avatar
projectSHO89
Your problem is the IAC.
Cleaning sometimes helps. Often, replacement is required.
Steve
Old Dec 22, 2005 | 09:40 AM
PaulC's Avatar
PaulC
If you can afford to, replace it.
Old Dec 22, 2005 | 09:43 AM
ford390gashog's Avatar
ford390gashog
i would replace it, cleaning is a temp fix.
Old Dec 22, 2005 | 09:56 AM
kccollier's Avatar
kccollier
Ok guys, I will give it a shot! I appreciate your help.
Old Dec 31, 2005 | 11:06 AM
2kEXPY's Avatar
2kEXPY
To amplify what the others have said, I too had the same problem and it was the the IAC. Buy new it'll save you some headaches in the future. They are about 30 bucks.
Old Dec 31, 2005 | 11:09 AM
kccollier's Avatar
kccollier
Thanks guys, I just wanted to post back and say I replaced the IAC valve and the problem is fixed. Workes great now! Thanks again for your help!
