fuel pressure too high?
Old Dec 21, 2005 | 07:48 AM
datchew's Avatar
datchew
1980 f100 inline 6
just installed new carb
I noticed a gas leak around the line feeding into the carb.
I loosened the clamp to cut the end off and clean it, and the hose SHOT off and squirted as all the way to the firewall. Glad it shot away and not toward me.
Anyway, it's a mechanical fuel pump and I wouldn't think that fuel pressure should be that high on it.
Also, sometimes when I shut the truck off, it will kind of make this growling noise and it's almost like it's dieseling. It wants to turn over a couple more times and I'm pretty sure it's shooting gas backwards out the top of the carb.
I've replaced all the vacuum lines that are left so I'm certain there's no vacuum leaks.
Any suggestions?
Old Dec 21, 2005 | 02:43 PM
fordborn's Avatar
fordborn
Thread moved to " Inline Six, 200, 250, 4.9/300" tech forum. See if you will receive more responses here.
Old Dec 21, 2005 | 03:51 PM
datchew's Avatar
datchew
ok. Thanks much.
Old Dec 22, 2005 | 07:22 AM
datchew's Avatar
datchew
well, i fixed the fuel leak, and maybe it's supposed to have that much pressure.
However, it still wants to turn over a time or 2 after I shut it off...
any ideas?
Old Dec 22, 2005 | 03:06 PM
srercrcr's Avatar
srercrcr
Turn over? You mean like dieseling? That's usually a timing issue, but I recall reading about a solenoid that plunges when it has been shut off....I guess closes the throttle.
Not positive it pertained to this 300 though. Check your Chiltons.
