Breakerless ignition module
Old Nov 19, 2001 | 12:12 AM
Franklin2's Avatar
Franklin2
Old Dec 15, 2001 | 08:57 AM
Eric111's Avatar
Eric111
How do you check a breakerless ignition module on a 1975 Ford pick-up?
A diagram would be great--web sites that have been visited to obtain
one are out of existence. My frustration level has reached the max! Thanks! :-(
Old Dec 15, 2001 | 02:45 PM
5050bar's Avatar
5050bar
Eric-
I have had 2 failures on my 78 F250, 460 engine. I found a good way to check the module is to measure the voltage at the cold side of the coil primary. The cold side is the one that the module switches. With the key on, the voltage should be around 0.6 volts. With the engine cranking, this voltage should show a pulsing on the meter. If the voltage stays at a steady 0.6 volts, the module is likely bad. Don't overlook the possibility of the impulse coil in then distributer being bad. Its resistance should be around 800 ohms. I got an Echlin module from NAPA that lasted 2 months past the warranty, which was 1 year. The one I am currently using is from Kragen and has a 5 year warranty, and cost about half the price of the Echlin. Good luck!
Bill
Old Dec 15, 2001 | 05:10 PM
jowilker's Avatar
jowilker
Eric, The best way is to buy and carry a spare, and when have problems plug the spare in. If the truck fires, test complete. Then you buy another spare.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 16, 2001 | 10:10 PM
75SuperCab's Avatar
75SuperCab
Post Breakerless ignition module
Eric, I used the electronic ignition troubleshooting instructions in the back of a 1980 Chilton passenger car manual that covered back to 1973. As I recall, the 1974 to 1976 ignition systems were called SSI (Solid State Ignition, with a different test procedure for each year). Ford changed to the Dura Spark system in 1977, with both a Dura Spark I & a Dura Spark II being a possibility, at least in the passenger car line.
John Boylan
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
