Water Neck Shape?
Old Dec 20, 2005 | 06:19 PM
The Eddie's Avatar
The Eddie
Question Water Neck Shape?
What does the water neck on your year 6.9 or 7.3 look like? Does it exit straight up, out the side, at an angle...?
Two bolts or three?
Sounds weird, but I am planning on using one on something else (maybe).
Eddie
Old Dec 20, 2005 | 11:05 PM
Spectramac's Avatar
Spectramac
Two bolts (5/16"), mounts on same angle as the pass. side head surface of the block, then goes straight up.
That tell you anything?
Old Dec 22, 2005 | 07:16 AM
The Eddie's Avatar
The Eddie
It Helps A LOT!
Thanks!
Two more questions, then I will leave you alone...
1. What year and model is this from?
2. What is the water neck's oulet (hose end) diameter?
I'm hoping for 2" but I suspect its 1.75".
Thanks,
Eddie
Old Dec 22, 2005 | 11:27 AM
Spectramac's Avatar
Spectramac
It's the same piece from 83-94 as far as I can remember. I would guess the hose is closer to 2". So what are you wanting to put it on, enquiring minds wanna know?
Old Dec 22, 2005 | 12:55 PM
82F100SWB's Avatar
82F100SWB
Let me think here, Nissan SD-33T I bet... In a Scout, or possibly a certain 91 F150...
I'll grab a couple pics of the neck on my 6.9 this afternoon.
Hose I think is 2"
