Sponsored by: Real Truck
05 250 bent frame
Old Dec 20, 2005 | 02:03 PM
ZRT 1000's Avatar
ZRT 1000
05 250 bent frame
I have a 05 250 with a 8' Western Ultra mount, I hit a stump last year, but not harder than I have hit stuff in the past with other trucks that I have. I have actually hit things on purpose harder with other trucks. well this hit bent the frame. I had the frame on the truck straightened and it has bent twice more without hitting anything. Does anybody else have a similar problem or know of anybody? ..Thanks Bill
Old Dec 20, 2005 | 02:10 PM
99f350sd's Avatar
99f350sd
So what actually bent? It takes an awfull lot to bend these frames. Is it in the crush zone ? You can get new one's I've heard.
Old Dec 20, 2005 | 04:18 PM
ZRT 1000's Avatar
ZRT 1000
It bends right behind the front tire on the drivers side. It bends very easy. This is the first year for the coilspring front so there are no leafs to give added strength. I think there is a problem with this frame.
Old Dec 20, 2005 | 05:26 PM
BerkshireCoverit's Avatar
BerkshireCoverit
Unhappy
Wow thats hard to beleive ,I've always heard ford has one of the best frames out there for plowing, I have been plowing with an 8 ft fisher on my 01 going on 5 years now and have hit many stumps,boulders and trees along my road when plowing. Never got any frame damage or frontend damage. Have heard of alot of Dodge frames bending while plowing, but never a Ford. Think i'd be sick if i had a 05 and that happened to me. Hope you get to the bottom of it. gl Mike
Old Dec 20, 2005 | 06:37 PM
Ace!'s Avatar
Ace!
Which way does it bend? Inward, side-to-side, up or down?
Old Dec 20, 2005 | 07:57 PM
ZRT 1000's Avatar
ZRT 1000
It bends the rail down, About 1" this time...
Old Dec 20, 2005 | 08:02 PM
99f350sd's Avatar
99f350sd
So it must crease something? I would have a welder make it so it doesn't do that if ford won't give you a new frame.
Old Dec 20, 2005 | 10:25 PM
donjamer's Avatar
donjamer
Maybe it is the way the plow is bolted on to the frame. I would suspect maybe they left off some support brackets. I know some plow frames had supports that connected way back on the frame under the cab. You might want to check with the plow manufacturer.
Old Dec 20, 2005 | 10:52 PM
99f350sd's Avatar
99f350sd
Is the truck stock?
Old Dec 20, 2005 | 10:59 PM
NickFordMan's Avatar
NickFordMan
I find this very hard to take in. Ford has the thickest frame of the bunch right now, and the frames are sturdy. This is the first time I've ever heard of something like this.
Old Dec 20, 2005 | 11:44 PM
2002 F350V10's Avatar
2002 F350V10
Obviously you hit very hard, and weakened the frame. The problem is not the truck frame, but basically the facts are you had an accident (with the plow hitting an object) with frame damage and an incorrect repair, also possibly some checking to see if all the mounting brackets were used. Time to call the insurance co for a claim. A fellow worker was plowing and hit a sewer cover hard and it sent him into the windshield , and put 6 ripples or buckles on the both sides of the truck in similar spots. also a bent frame . total damage was $4800 and the insurance co paid it. Things happen.
Old Dec 21, 2005 | 09:53 PM
Ace!'s Avatar
Ace!
Yep, you will probably get a new frame through insurance, as I doubt they have a sectioning procedure for it (although they might). It's a safety issue at this point. An impact to the front (not plowing) will no longer throw the air bags at the right timing and probable frame failure in another impact. You should definitely get it to a reputable body shop with proper frame set up to determine what needs to be done.
Old Dec 21, 2005 | 09:57 PM
99f350sd's Avatar
99f350sd
Sure does sound like its weakened now..A heavier truck will cause more damage with out the driver feeling the impact as much.
Old Dec 21, 2005 | 11:22 PM
jake00's Avatar
jake00
can you snap a picture and post it?
Old Dec 22, 2005 | 03:27 AM
BerkshireCoverit
I been thinking this also , Bad install of the plow frame, but also, have an uncle who owns an old school bodyshop (still uses lead in body repairs last time i heard) anyway once he told me a frame should never be heated or maybe it was overheated as it weakens the steel, was just wondering if the plow installer might have used a tourch to burn holes, instead of drilling.
