Sponsored by: Kumho
steering stabilizer help?
Old Dec 20, 2005 | 12:16 PM
Grant12's Avatar
Grant12
Question steering stabilizer help?
I have a 2003 supercrew FX4 with 11 inches of lift ,38.5 by 16 baja claws what would be a good stabilizer set up she steers great but would help tighten up the steering and help a little on the mickey wobble ? appreciate ya!
Old Dec 20, 2005 | 03:12 PM
ivanribic's Avatar
ivanribic
I recommend you don't mask front end problems by adding stiffer stabilizers or more of them. There's no reason 1 stabilizer shouldn't handle that fine. If you have a wobble due to the tires on the truck then you should look into getting them balanced properly. A lot of guys put on massive stabilizers and never pay attention to the source of the vibrations, letting situations go until it's too late.
That all being said Rancho and Skyjacker both make brackets that can be used for dual stabilizers.
Old Dec 20, 2005 | 05:33 PM
Grant12's Avatar
Grant12
Thanks but Im not trying to resolve the problem this way I just had them balanced and they only wobble a little at 42 mph.Just wanted to know whats the best way to go and will it help or change anything and which set up is best for me?appreciate ya!
