hiboy power steering
Old Dec 20, 2005 | 12:20 AM
nebechanezer's Avatar
nebechanezer
'77 hiboy, 400, at, d44 front, and the steering ram leaks. was looking at my NPD catalog and found a seal kit, power steering cylinder, part # f-3a764-2. says for 74-77 f250 4x4, w/ bendix control valve. is this what i'm looking for to fix my leaks
Old Dec 20, 2005 | 12:30 AM
FordPickup460's Avatar
FordPickup460
That should be it, but I dont have my NPD catalog handy. I wish I found the seal kit before I spent $375 on a new cylinder.
You might want to look into replacing the power steering lines also. After I replaced my ram, the old lines blew.
Old Dec 20, 2005 | 07:04 AM
74fordhighboypickup's Avatar
74fordhighboypickup
Before you do that, you might try Lucas Oil Power Steering Stop Leak. My 74 leaked for 15 years before I put the stop leak in it. It hasn't leaked for over three years now.....
Old Dec 20, 2005 | 10:21 AM
nebechanezer
i did try the lucas oil, worked on my ranger a few years ago, but this one leaks too much, didnt help any. dont really want to buy a new cylinder. has anyone used this kit, was wondering how difficult the install is. thanks, neb
Old Dec 20, 2005 | 12:06 PM
J&B's Avatar
J&B
replacing the seal should be easy . I've replaced many on pumps and pistons for other applications . make sure the rod is smooth and cleaned of all burrs. sand with a fine micron paper , also coat with a silcon grease before sliding over the new seal. Now , I need this also and could not find a seal kit anywhere . 20 bucks is better than 300 . where can I get this catalog you found the kit in .
thanks Jack.
Old Dec 20, 2005 | 12:31 PM
nebechanezer
go to www.npdlink.com , you can order a catalog online, or call 1 800 368 6451 or 1 800 874 7595. they have a few different catalogs, ask for the 1948-1998 ford truck one. they have a lot of stuff, i've haven't ordered from them yet, though. the seal kit is $38.33. i thought www.lmctruck.com catalog had a similar kit but i cant find it now, i might have been mistaken.
1976HiBoy
Oct 24, 2011 01:15 PM
bsneed
Sep 18, 2010 06:54 PM
badass75 hiboy
Sep 1, 2008 07:29 PM
400Nut
Aug 30, 2006 09:37 PM
