1978 - 1996 Big Bronco
ignition switch rod
Old Dec 19, 2005 | 09:27 PM
ratsrides2's Avatar
ratsrides2
ignition switch rod
i replaced the ign switch on the colum and to my suprise the rod moves sideways instead of straight, will not start the truck, help on changing rod would be deeply appreciated,
ford bronco 1988,5.0 4x4 full sized, fully loaded with tilt,cruize,air power windows,rear power windows and it is a collum shift automatic.
Old Dec 20, 2005 | 11:20 AM
bertha66's Avatar
bertha66
You my want to pull your switch out agianand see if you got it in right. I don'dt thinnk it should be moving any differant than what was in it before, or you got the wrong switch.
Old Dec 21, 2005 | 06:14 AM
ratsrides2's Avatar
ratsrides2
ignition rod reply
you probley did not understand my problem, the rod is moving to the side where the key switch is at, not at the electrical end. it is in the upper part of the steering column collor where the key is at.all else is ok
Old Dec 21, 2005 | 12:33 PM
moritz1024's Avatar
moritz1024
i took my steering column out completely and had absolutely no trouble replacint everything with components. i dont think u should have started that project. lol
Old Dec 22, 2005 | 10:27 PM
Plevna's Avatar
Plevna
Sounds to me like the rod came loose of the yoke, and is being pushed to the side when you turn the key.
Old Dec 23, 2005 | 06:00 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Plevna, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 24, 2005 | 09:56 PM
ratsrides2's Avatar
ratsrides2
thank you
i just wanted to say thanks for alowwing me in your forums, the problem was in the yoke and the slide was wore out, changing the collor and everything is ok now, thanks for all the advice.
Old Jan 17, 2006 | 06:32 PM
JacksonSoccerBoy's Avatar
JacksonSoccerBoy
Could you plase tell me what you had to do to fix this ? I recently had this happen to mine and was starting to think I might have to replace the whole steering colum.
