bolt help
Old Dec 19, 2001 | 06:58 PM
drumman123's Avatar
drumman123
Post bolt help
I need some suggestions. I cannot get the bolts out of the front fenders that hold on the grill. I realize that after 30 years they are rusted. I have tried everything to get them off, any ideas. I would be more than willing to cut or break them off but they are in such a tight space Im not sure how to go about doing it Please, if anyone knows a way, let me know
Thanks,
Jeff
71 f250 camper special w/ soon to be 460-c6
Old Dec 19, 2001 | 07:07 PM
jkirisits's Avatar
jkirisits
bolt help
Jeff,
Have you tried coating them with PB blaster, or wd-40, every day for a week or so?
Can you head them with a torch without melting anything important?
John
Old Dec 19, 2001 | 07:19 PM
Matt67's Avatar
Matt67
bolt help
Depends on the condition of the bolt heads. I'f there not rounded off already, try the "PB-Blaster". I'm guessing theres no way to get an impact wrench in there, because thats what I'd sugest first if you could. :-bang
Old Dec 19, 2001 | 07:25 PM
drumman123's Avatar
drumman123
bolt help
impact, wd-40, 300lbs friend, everything. I can't get in there with a torch without destroying the grill. the funny thing is I can get them loose one or tow turns maybe and thats it. I am pulling my hair out, well if I had any I would
Thanks
Jeff
Old Dec 19, 2001 | 07:37 PM
Matt67's Avatar
Matt67
bolt help
Try "PB-Blaster", Its a whole lot better. I've seen many bolts taken out with it, that WD-40 couldn't move.
If you can get them a little loose, then work them back and forth, thats what The guys from "Shadetree Mechanic" said....
Old Dec 19, 2001 | 07:50 PM
drumman123's Avatar
drumman123
bolt help
Thank for the info, now I can't wait for my next day off
Jeff
Old Dec 20, 2001 | 07:11 PM
mk's Avatar
mk
bolt help
Which bolts exactly are the problem ones?
Old Dec 20, 2001 | 07:48 PM
drumman123's Avatar
drumman123
bolt help
they are the ones that are up behind the headlight, they are a bear to get to.
Jeff
Old Dec 20, 2001 | 08:00 PM
DAV1972's Avatar
DAV1972
bolt help
[updated:LAST EDITED ON 20-Dec-01 AT 09:02 PM (EST)]If I remember correctly the bolts go through the grill and into some clips that are on the fenders. Could you break the clips? You would want to put new ones in anyway. Maybe a cutoff wheel or Dremel tool?
Old Dec 20, 2001 | 08:04 PM
drumman123's Avatar
drumman123
bolt help
I might be able to get to them, they are on the grill side and I dont want to tear up the grill but I will try that thanks
Jeff
Old Dec 20, 2001 | 09:29 PM
RangerBill's Avatar
RangerBill
bolt help
