Better Engine Swap
Old Dec 21, 2001 | 08:40 AM
ford racer 02's Avatar
ford racer 02
Better Engine Swap
I have a 78 frod f-150 and i was wondering if it is possible to put a 352 motor in it and if everythign will bolt right up??
Old Dec 21, 2001 | 09:41 AM
Franklin2's Avatar
Franklin2
Better Engine Swap
What motor did it have, or is in it now?
Old Dec 21, 2001 | 09:45 AM
Bill_Beyer's Avatar
Bill_Beyer
Better Engine Swap
>up??
No it won't. The FE series has a unique bellhousing bolt pattern which won't match any of the engines which came stock in a 78. You'll need to swap out the whole tranny if it's an auto or the bellhousing if it's a manual.
Old Dec 21, 2001 | 06:27 PM
RangerBill's Avatar
RangerBill
Better Engine Swap
Engine mount pedastals, mounts, and trans will need swapped, for starters. However, there were thousands and thousands of '73-'76 360 & 390 equipped trucks that would make good parts donors, and are littering boneyards all over the country.
I think (may need corrected here) that you could also scavenge parts from the '65 - '72 trucks, too (same basic engine cradle & same Twin-I set-up from '65 - '79, with minor revisions along the way). These rigs also were easy to find with an FE series motor under the hood.
Old Dec 21, 2001 | 07:20 PM
classyfish's Avatar
classyfish
Better Engine Swap
