Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
tools you have made yourself
Old Feb 1, 2007 | 05:36 AM
  #61
tewferford's Avatar
tewferford
Sorry about the joke. Bad taste. I do have a bathroom in my garage tho.
Frank
Old Feb 1, 2007 | 07:12 AM
  #62
frederic's Avatar
frederic
Cool thread.
I made homemade workbenches:
http://frederic.midimonkey.com/yard/garage/IM001765.JPG
And yes, that odd "frame" sticking out has a purpose. It houses my homemade CNC plasma cutter machine:
http://frederic.midimonkey.com/cnc2/IM001903.JPG
I made a homemade tamper (Hey, it's a garden tool!):
http://frederic.midimonkey.com/yard/IM001102.JPG
A homemade welder stand (for two welders):
http://frederic.midimonkey.com/yard/...t/IM001659.JPG
An engine run stand:
http://frederic.midimonkey.com/runstand/runstand-16.JPG
A base for my bandsaw so I can roll it out of the way:
http://frederic.midimonkey.com/yard/...e/IM002160.JPG
Made a few "BXA" holders for my lathe's toolpost:
http://frederic.midimonkey.com/yard/...a/IM002143.JPG
Made a cutting fluid/coolant system for my lathe and floor-standing drill press which is right next to it:
http://frederic.midimonkey.com/yard/...t/IM001763.JPG
Made a lathe steady rest for better clamping while turning the ID of tubing:
http://frederic.midimonkey.com/yard/...t/IM002234.JPG
Made a collet holder for my lathe (drawbar):
http://frederic.midimonkey.com/yard/...g/IM002090.JPG
Then made a more massive version of the drawbar:
http://frederic.midimonkey.com/yard/...g/IM002169.JPG
Made several "giant" t-slot nuts, which I use to mount odd things onto my lathe's saddle in place of the toolpost.
Also made an end mill holder for my lathe, which I used to hold a large end mill so I could make the t-slot nuts and various other things:
http://frederic.midimonkey.com/yard/...g/IM002145.JPG
While not a tool, I did make a 13.5' wide steel open-frame table for my studio gear: http://frederic.midimonkey.com/studio/IM000785.JPG
There's more but that's what I can think of at the moment,
Old Feb 1, 2007 | 11:21 AM
  #63
tjc transport's Avatar
tjc transport
i ain't rite
hey fred, don't forget "superbumper"
Old Feb 1, 2007 | 03:58 PM
  #64
rogerf100's Avatar
rogerf100
My son-inlaw and I built the stand my 292 engine is sitting on. The parts came from an old weight lifting machine that had been scrapped. We cut the base to narrow it and welded it back together. Added casters up front so it could be moved around.
https://www.ford-trucks.com/user_gal...oid=67673&.jpg
Old Feb 1, 2007 | 06:48 PM
  #65
frederic's Avatar
frederic
That's true, technically superbumper is a "tool" because it's useful for recycling imports
Old Feb 1, 2007 | 10:39 PM
  #66
fatboyf150's Avatar
fatboyf150
when i was working for john deere in mannheim, germany. i took a 1 5/8 hex drive shaft from a 7200 6 row JD planter and cut it me 2 pieces about 2.5 feet long and cut one into a super punch and heated the other bar, pressed one end flat and made a super chisel out of it. they are extream, but i have used them time and time again. i havent needed anything any bigger so far.
Old Feb 2, 2007 | 02:57 PM
  #67
fastfordmobile's Avatar
fastfordmobile
I made a tool for cleaning my gutters. I fastened an air blower on the end of a flexible plactic pipe and put a bend in the end so it would blow down into the gutters and blow out the leaves. I didnt need a ladder anymore. I could stand on the ground and use it.
Old Feb 4, 2007 | 04:36 PM
  #68
200000+F150's Avatar
200000+F150
Bunches of specialty wrenches, spanner screwdrivers, circle-cutting jig for the plasma, etc. Lots of electronic test equipment. Cheap wrenches and sockets do have their place!
Old Feb 8, 2007 | 05:56 PM
  #69
ckal704's Avatar
ckal704
Made a leak-down tester for small engines before the mfrs. came out with one.
Various wrenches/drivers as needed. Made an impact puller for stack pulleys on lawn tractors that works great.
And in the Boy Scouts I made a left-handed smokeshifter.
I also made a "boardstretcher" that I give to my first-year wood shop students to use when they complain to me that they cut a board for their project too short.
Old Feb 13, 2007 | 10:18 PM
  #70
pursang's Avatar
pursang
My Homemade steel bender, thick steel plate with a few grade 8 bolts installed
as pins, and a big long heavy bar. works great.
http://i70.photobucket.com/albums/i8...s/IMG_1549.jpg
http://i70.photobucket.com/albums/i8...s/IMG_1550.jpg
http://i70.photobucket.com/albums/i8...s/IMG_1551.jpg
Various round dies.
http://i70.photobucket.com/albums/i8...s/IMG_1561.jpg
Old Feb 13, 2007 | 10:20 PM
  #71
pursang's Avatar
pursang
This tool I made for removing valve seals on a Suzuki GS 1000 engine, can also be used
for pulling other stuff, like tough spark plug boots in tight spots.
http://i70.photobucket.com/albums/i8...s/IMG_1548.jpg
Simple homemade threaded puller.
http://i70.photobucket.com/albums/i8...s/IMG_1547.jpg
Old Feb 13, 2007 | 10:22 PM
  #72
pursang's Avatar
pursang
I have a stainless steel kitchen sink installed in my bench and this washing machine motor
along with a barrel pump, an old beer keg and the washing machine controls make a
great solvent station.
http://i70.photobucket.com/albums/i8...s/IMG_1545.jpg
http://i70.photobucket.com/albums/i8...s/IMG_1546.jpg
Old Feb 13, 2007 | 10:24 PM
  #73
pursang's Avatar
pursang
Simple buffing/polishing contraption.
http://i70.photobucket.com/albums/i8...s/IMG_1556.jpg
Drill Press Tool Holder.
http://i70.photobucket.com/albums/i8...s/IMG_1557.jpg
Old Feb 13, 2007 | 10:27 PM
  #74
pursang's Avatar
pursang
Flat base plate for cross slide vice on drill press.
http://i70.photobucket.com/albums/i8...s/IMG_1552.jpg
http://i70.photobucket.com/albums/i8...s/IMG_1553.jpg
Old Feb 13, 2007 | 10:29 PM
  #75
pursang's Avatar
pursang
Simple adjustable stand.
http://i70.photobucket.com/albums/i8...s/IMG_1554.jpg
http://i70.photobucket.com/albums/i8...s/IMG_1555.jpg
This little fellow keeps the shop cool in hot summer.
http://i70.photobucket.com/albums/i8...s/IMG_1563.jpg
