AODE to AOD
Old Dec 19, 2005 | 05:22 AM
scholls's Avatar
scholls
AODE to AOD
Hi all , first post when through lots of old post about AODE transmission probably missed what I was looking for . I have a 95 f150 with 5.0. The aode when out cant find one where I live. I have a aod out of a Mercury with 56,000 miles . I now it will bolt up . And I have to change the shift lever from facing down to facing up. I don't see and any speedometer sensor on the aode , the mercury trans has one . Whats up here? And I probably need different drive shaft any help! I got the next two days off need to get this done this is the only thing I have to drive. Need Help , will be pulling the transmission out this morning.
Old Dec 19, 2005 | 05:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 19, 2005 | 06:52 AM
subford's Avatar
subford
First the Transmission you have is and improved version of the AODE and is called the 4R70W Transmission. Try to look for this one.
The AOD is shorter than the 4R70W and the crossmember is in the wrong place.
The Speed information in the 95 comes from the VSS sensor on the top of the rear end.
The PCM receives information from the 4R70W and shifts the transmission.
You will get some errors from the PCM with the AOD.
