Driveshaft Problem
Old Dec 18, 2005 | 05:52 PM
Brotzy's Avatar
Brotzy
Question Driveshaft Problem
2003 Ranger 4X4 Edge. Driveshaft has clicking noise when first starting out. Goes away at 10 MPH. U-Joints OK. Something loose inside driveshaft near the rear. When you hit it with you hand you can hear something moving inside. Anyone ever hear of this?
Old Dec 18, 2005 | 11:05 PM
el conquistador's Avatar
el conquistador
is the truck still under warranty? if so, your best bet is to let ford deal with it.
Old Dec 19, 2005 | 12:01 AM
texan2004's Avatar
texan2004
I heard a story once about a bunch of wleding rods being found in the door threshold of a mid 70's Ford Thunderbird. When they cut the threshold open to pull out whatever was in there, they found a bundle of welding rods with a note that said, "congratulations, you found the noise". This of course occured in the mid 70's.
Old Dec 19, 2005 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 19, 2005 | 12:32 PM
Brotzy's Avatar
Brotzy
Cool
Truck just out of warranty of course!
Old Dec 19, 2005 | 01:16 PM
RangerPilot's Avatar
RangerPilot
Well your best bet is to pull it and see if it still makes the noise outside. If something is inside, once it gets going the centrifugal force pins it to one side and it doesn't move again. So yeah, I bet you have something loose inside. If it comes off and still makes the noise, you're gonna have to cut into it one way or another. Might be kinda fun to see what's inside though.
Old Dec 19, 2005 | 08:02 PM
el conquistador
you better take it into a shop that works with driveshafts and drivelines. you cant simply cut a hole in it and weld it back together because it will throw the balance off.
