C-6 output shaft
Old Dec 18, 2005 | 04:49 PM
bpete's Avatar
bpete
C-6 output shaft
What is the difference? Went to swap out a C-6/205 in a 78 Bronco for a C-6/205 from a 78 F-150 & noticed the adaptor between the trans & t-case is appx. 3" longer than the F-150's. Does the Bronco use a longer output for a reason or is it using a 2wd trans output shaft?
Old Dec 18, 2005 | 08:13 PM
RTM's Avatar
RTM
responded to your other post. They are both 4x4 trans, not 4x2. The 4x2 would have the wrong output shaft which would be even longer than the bronco set up.
Old Dec 18, 2005 | 08:20 PM
bpete's Avatar
bpete
Thanks for the reply. I was hoping that the 2wd output would be the same though.
