The Continuing Temperature gauge story...
Old Dec 18, 2005 | 02:50 PM
agryphon's Avatar
agryphon
I changed out my temp sender ('93 2.3L), and the gauge worked for one day. I had some time today, hooked up an ohm meter to the temp sender, and started it up. Sure enough, the sender is working fine. Could watch the resistance drop while the motor warmed up, could even tell when the thermostat opened...
So I hooked the gauge lead back up to the sender, and nothing... So I grounded the lead and that pegged the temp gauge...
Well, I hooked it back up, and started tapping on the gauge... which promptly moved into the appropriate temp reading on the gauge...
Just seems to be a little 'sticky' at the low end of the scale... So, perhaps simply grounding the lead to test the gauge isn't something ya ought to rely on 100%...
Can I purchase any aftermarket temp gauge? Is there anything in particular I need to know about or look for in a gauge? And can I just use the stock sender to drive it?
Old Dec 18, 2005 | 06:53 PM
RangerPilot's Avatar
RangerPilot
Yeah. I put a set of gauges in my console including water temp. I don't know of any aftermarket gauges that won't use the stock sender. You just tap into the wire (it was purple/white on my '94) and run it to the gauge. I'd suggest putting it somewhere out of sight but easily accessable since it doesn't match the stock gauges. Autometer makes good gauges, little pricey though.
Old Dec 18, 2005 | 09:33 PM
wtroger's Avatar
wtroger
I would never use electric aftermarket temp or oil pressure gauges use mechanical they are more accurate. And pick a good manfacture Sun or someone like that not the cheap Wally-world Chinese knock offs
Old Dec 18, 2005 | 10:55 PM
RangerPilot
Never had problems from them. I have Sunpro gauges, all electrical. I can back up both readings mechanically for those who don't believe electrical gauges.
Old Dec 19, 2005 | 05:41 AM
Bob Ayers's Avatar
Bob Ayers
Tapping 2 gauges into the same sending unit is not a good idea. By doing this, you will have 2 current sources going into the same sending unit, which
can throw the readings off in both gauges.
Old Dec 19, 2005 | 06:03 PM
wtroger's Avatar
wtroger
The problem with electrics is they will also reflect the condition of your electrical system. they will read high or low depending on battery condition and alternator output and electrical load I have seen my Fords swing a long way based on voltage fluctuations. I will stand on my previous post mechanical all the way.
Old Dec 19, 2005 | 06:11 PM
Bob Ayers's Avatar
Bob Ayers
Most instrument panels have a voltage regulator with an output voltage much lower than the battery voltage (like 10V) to power the gauges. This
minimizes the effect on gauges from battery voltage flucuations.
Old Dec 21, 2005 | 08:31 AM
wtroger's Avatar
wtroger
Ford does indeed run a voltage regulator for the gauges it is supposed to produce pulsating 5 volts. But still I have had both the electric and a mechanical running at the same time and the electric would swing all over the gauge the mechanical stand rock solid.
It is really kinda of a moot issue remeber Ford really doesn't want you to know what is going on in there engines. These are the folks that give us IDIOT OIL GAUGES Where 7 lbs of oil pressure will show on a gauge as mid range. Or 75 lbs of oil pressure will still show mid range.
Old Dec 21, 2005 | 02:56 PM
RangerPilot
I have a hard time believing you for the most part wtroger. "Swinging" gauges is a farfetched possibility. Perhaps it's time you got a real battery that could hold your electrical system? I've had no problems from mine. Definetly no gauges swinging about. It would be much simpler for him to tap into the wires and run a gauge off than to attempt to run a mechanical gauge. The procedure I used was given to me by someone knowledgable not only in electrical but in Rangers as well and it was detailed and took a good bit of time. It's not just hacking into the wire and attaching it as the thought seems to be. Electrics are just a little more complicated than that.
Old Dec 21, 2005 | 08:37 PM
Piffery1's Avatar
Piffery1
A bad instrument cluster voltage regulator can cause gauge fluctuations at least on older models. I had a '71 Econoline that the oil pressure and temp gauges constantly fluctuated between the high and low ends of "normal" due to a bad regulator. Fuel gauge would have done the same if it had had a working sender. New regulator fixed the problem. My current '83 F350 gauges do it too, but only about half the width of the needles.
Old Dec 21, 2005 | 10:53 PM
RangerPilot
But he talks of just one, which doesn't make sense. If the gauge was going out perhaps but that is a farfetched possibility just as well.
Only gauge I've seen flickering was my dad's voltage gauge with the blinker on. Good God that blinker draws the voltage. Yellow-top and the Big-3 fixed that!
Old Dec 22, 2005 | 04:07 PM
tekrsq's Avatar
tekrsq
An idea I've been playing with is to get the gauge clusters that have the fuel/temp & oil/volts guages in them, gut them, cut holes, and install aftermarket Autometer gauges in place of the stockers. I'm just wondering if they have to "tie in" with the tach/speedo cluster somehow to make them (or the truck computer/sensors) work, or if it's 3 seperate clusters? I also wonder if I could tap into the existing wiring from the stock sending units (except the oil pressure), or would I have to leave the existing harness, and run wires from the new sending units. Would leaving the dash harness unplugged, interfere with the truck computer?
Some gauge companies make "mini" gauges. I might be able to install them and a tranny temp gauge if they're small enough and it doesn't interfere with the other truck electronics.
Old Dec 22, 2005 | 06:43 PM
dono's Avatar
dono
Gone but not forgotten.
Buy a good gauge, install it properly and you will get a good reading. Mechanical gouges usually have 270 degree sweeps and make direct contact with what they are measuring. They can be checked by placing the cap tube in coolant and measuring with a thermometer. Electric gauges have 90 degree sweeps and are much easier to install. Most all senders are designed to drive one gauge and adding a second gauge will affect the reading.
Dono
Old Dec 22, 2005 | 08:58 PM
RangerPilot
Haven't had any problems to speak of with mine. Install took a bit but worked just fine. No change in stock gauge, aftermarket is reading perfectly. With real oil sender finally both of the oil pressure gauges are reading good too.
As for the mini-gauges, I think Autometer makes them, I know SunPro does. They are 1 1/2" I believe? Could probably fit them all in. I would say use a gauge cluster with all the stock gauges including tach and replace all with matching gauges. Would look good in the end.
Old Dec 22, 2005 | 10:45 PM
wtroger's Avatar
wtroger
Believe what you want rangepilot I have more years expierence working on these Fords than I care to count. And I will never buy or install an electric oil or temp gauge. There are just to many variables introduced by electical gauges IE: bad batteries, flakey alternators poor connections bad grounds etc etc. So why not just eliminate those and go with a pure mechanical connection(s). Agryphon is looking for a solution not argument about gauge types. You can test the gauge in the dash, on the connector that goes on the sender that is in the block hook up a ten ohm resistor and ground the other end turn on the ignition the gauge should go to H (hot) next hook up a 75 ohm resistor and ground the other end it should read C (cold) If it reads as it should replace the sender. If it doesn't read right check the wiring or replace the gauge. And that is straight out of the Ford shop manual.
