clark input shaft
Old Dec 17, 2005 | 09:01 PM
mtpcage's Avatar
mtpcage
clark input shaft
is the clark in put shaft longer than T98 or T89. Replaceing an engine and dont know if changes need to be made to the new engine for the clark trans
i have some pics of the trans in my gallerie will put one of the shaft in the am.
please help
Old Dec 20, 2005 | 12:02 PM
794x4390's Avatar
794x4390
Are you sure that's a Clark? What is the model #? Assuming you are replacing the engine with the same type (FT?, FE?) you shouldn't need to make any changes other than swapping the flywheel/clutch. I don't know specifically if the input shafts are different lengths. They do take a different bellhousing and the Clark is 1-3/8" instead of 1-1/16" (I think that'd the size of a t98). Exactly what are you mating to what?
Old Dec 20, 2005 | 05:33 PM
mtpcage's Avatar
mtpcage
thanks, its a clark . Whish it wasen't . its all lineing up know
