Battery light
Old Dec 17, 2005 | 01:31 PM
copper's Avatar
copper
Unhappy Battery light
Hi everyone.
Last night while I was driving the battery light on the dash was coming on and going off. The voltage gauge stayed steady. If the truck was idling the light stayed off. If the engine was reved up the light would come on. This morning the light will not come on. This is a stock 2k 250 4X4 extended cab. The only excessory is a remote starter. Anyone have any ideas?
Old Dec 17, 2005 | 10:08 PM
cangim's Avatar
cangim
I'd start by having the batteries tested, 2K is still about 5 yrs of life if they are the originals.
Old Dec 17, 2005 | 10:14 PM
PSNut's Avatar
PSNut
Originally Posted by copper
Hi everyone.
If u have A voltmeter the batteries should be 12.5volts with truck off and no more than 14.5volts while engine running.
Old Dec 17, 2005 | 11:38 PM
empiretc's Avatar
empiretc
That sounds like a classic case of terminals needing to be cleaned. Some arm$hammer, 1/2in wrench, pair a pliers and a knife should do it.
Side note. Hope they are good battery cables and not the cheapy type. Those will cause all kinds of problems.
Old Dec 18, 2005 | 02:08 AM
agg_bagg's Avatar
agg_bagg
ya i had the same problem with my battery light coming on. as soon as i cleaned my terminals it stayed off and hasn't come on since.
Old Dec 24, 2005 | 12:56 PM
copper's Avatar
copper
Red face
I cleaned and tightened the battery terminals and it made no difference. I also checked the batteries. I load tested both batteries and the passenger side is getting weak. Since then I removed a bunch of wiring from under the dash. The truck was used as an ambulance and I think the wireing was for running the lights and siren or for a remote starter. I also found the clip to the signal light harness was broken.I repaired the harness and I have had no problems since but I am worried the problem will come back.
