1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Oxy Sensor, Bank 2, where is it?
Old 12-17-2005, 11:17 AM
tealboy1's Avatar
tealboy1
tealboy1 is offline
I have a code that showed up on my 98 exped, 4x4 5.4 liter, indicating a P0153, bank 2 sensor 1. Autozone tested and they have a sensor for $50 by Bosch. Is this a good replacement?
where is this sensor located and how are to replace? the light has been going off for 1 1/2 years. truck seems to run fine. what are the symptoms of not fixing?
pls advise.
Old 12-17-2005, 04:57 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
Bosch is a fine replacement. You'll find the HO2S1 between the engine and the cat (not after, that's the post cat sensor HO2S2). If you can get a 13/16" wrence on it, you'll be fine. Otherise they make special sockets that allow the wire to come out the side. (I'm not exact sure on your truck so you might need to get under it and have a look.)
If you don't get it fixed you'll likely suffer poor mileage.
celsoglima
1983 - 2012 Ranger & B-Series
05-05-2015 12:16 PM
applehead
20
12-08-2007 11:49 PM
njxlt
07-31-2007 05:27 PM
tc5210
26
05-17-2005 08:05 PM
Quick Reply: Oxy Sensor, Bank 2, where is it?
