92 Explorer fuse ?
Old Dec 17, 2005 | 09:19 AM
Shiner's Avatar
Shiner
Arrow 92 Explorer fuse ?
Since I didn't get an owners manual when I purchased this vehicle could someone on here post what each number is for on the fuse block cover. Because right now I have to go out and pull every 15 amp fuse to see which one is blown for for my turn signals.
Thanks!
Old Dec 17, 2005 | 03:05 PM
Shiner's Avatar
Shiner
Let me be more specific. Was trying to merge into another lane yesterday because of a traffic accident. Sitting there probably 15 minutes with my left turn signal on and then no signals at all. Looked at all the fuses and they look fine.
Old Dec 17, 2005 | 04:17 PM
savagefan's Avatar
savagefan
Does the right signal work? if so one of your left bulbs is burned out, if not check the flasher unit.
Old Dec 17, 2005 | 09:51 PM
JerrySimm's Avatar
JerrySimm
Check the flasher and lamps, as previously stated. However, it could also be the multifunction switch. It looks like fuse #5 powers the turn signals, a daytime running light module (if your's has that option, and the signal to the heater blower relay. A wiring diagram is located here; http://www.autozone.com/images/cds/g...3d800ba9d5.gif
pullinair
17
May 6, 2026 02:50 AM
GamerGirlAlice
Jul 8, 2013 06:13 PM
Leemakesmepee
Nov 24, 2012 04:44 PM
BaronVonAutomatc
Electrical Systems/Wiring
Apr 20, 2010 06:38 AM
WarOzz
Jan 16, 2010 07:38 PM
