Multifunction Switch
Old Dec 16, 2005 | 09:37 AM
twxsby's Avatar
twxsby
I am trying to make sure that this switch is bad before I throw down $145 to buy a new one. When I turn on my lights, only the running lights come on. If I put the high beams on, (lever forward) then my low beams come on. If I pull the lever back, My high beams come on. I replaced the headlight switch, didn't fix the problem. Do I have a "lights out moduale" (LOM)?
Thanks
Old Dec 16, 2005 | 08:40 PM
Ken00's Avatar
Ken00
Sounds bad to me but drop me an email and I'll send you the test diagram.
Old Dec 17, 2005 | 03:59 PM
oldgoat49's Avatar
oldgoat49
I have a 99 Mazda and the switch from the dealer was quoted at $70. parts and $170 parts and labor.
B. REPAIR PROCEDURE
Note:
^ Do not replace the GEM when performing this SSR
1. Record the radio stations presets and disconnect the battery ground cable.
2. Remove the tilt wheel handle by turning the handle counterclockwise (if equipped).
3. Remove the three (3) upper and lower steering column shroud retaining screws and remove the shrouds.
4. Remove the two (2) multifunction switch retaining screws, disconnect the electrical connectors, and remove the multifunction switch. Refer to the illustration.
5. Inspect the multifunction switch electrical connector pins to make sure they are not loose or pushed out in the connectors.
6. Connect the new multifunction switch, making sure the electrical connectors snap into place and are fully seated.
7. Install the new switch to the column and tighten the screws.
Tightening torque 3 Nm (27 lb-in)
8. Install the upper and lower steering column shrouds. Tighten the screws.
Tightening torque 1 Nm (9 lb-in)
9. Install the tilt wheel handle.
1O. Connect the battery ground cable, reprogram the audio presets and set the clock.
