offset on factory
Old Dec 15, 2005 | 04:35 PM
Josh0525's Avatar
Josh0525
offset on factory
does anyone know what the offset on the factory rims for a 94 f150?
thanks
Old Dec 15, 2005 | 06:18 PM
Lou Braun's Avatar
Lou Braun
I believe that the backspacing on the stock rims is 4 1/2 inches. Most rims were about 7 inches wide.
Lou Braun
Old Dec 15, 2005 | 06:34 PM
Josh0525's Avatar
Josh0525
so do you know if thats a positive or negative backspace or about even?....i need the offset measurements in MM's (millimeters) or IN.
Old Dec 15, 2005 | 06:56 PM
Josh0525's Avatar
Josh0525
lol someone please help me here, im about to buy some new wheels and i have the factory ones on there now with 2" spacers to offset them, i have a 3" body lift and 33's need to make sure im gonna clear the fenders with these rims i want
Old Dec 15, 2005 | 10:15 PM
Mark Wenner's Avatar
Mark Wenner
On my 93, which has the 7.5-inch wide alloys, I believe I measured about 3.75 inches of backspacing (it's been a while since I did it) meaning that the wheel basically has zero offset. If you want to check yours for yourself, the truck's data plate in the driver's side door jamb will specify your wheel width, and you can pull a wheel off the truck to measure the backspacing. There are numerous websites that explain the relationship between wheel width, backspacing and offset - if you know any two of the measurements you can calculate the third - here's one: http://www.rsracing.com/tech-wheel.html
