Sponsored by: Real Truck
Removing door panels
Old Dec 15, 2005 | 02:00 PM
dpbullseye's Avatar
dpbullseye
I have a speaker cutting in/out and need to get at it. How do the front door panels come off on a 2000 SD? I don't want to break it.
Thanks
Old Dec 15, 2005 | 02:06 PM
DD1684's Avatar
DD1684
Pop off the reflector at the bottom of the door with a flathead screwdriver, and pop off the switch panel for the door locks and windows. Under the reflector there is a hex screw to remove and the same goes for under the switch panel. I forget what size but you'll figure that out. Once you remove the two screws you should be able to lift up on the panel and it should pop right off. Hope this helps!
Old Dec 15, 2005 | 02:07 PM
dpbullseye's Avatar
dpbullseye
Thanks for the quick response!!
