front end troubleshooting
Old Dec 14, 2005 | 07:57 PM
caesarnapolitano's Avatar
caesarnapolitano
i have an 80 f150 that is making a knock when i stop and turn. i was wondering if anyone knows of a site that can help with troubleshooting on fords. or if someone can give me some feedback as to what theu think my problem is. my past experiences tells me it is the ball joints. i have a good idea how to test them. any other ideas? i also just replaced the tie rods.
Old Dec 14, 2005 | 08:53 PM
Piffery1's Avatar
Piffery1
Check for worn pivot and radius arm bushings; shouldn't have any visible "play" in them. To check you'll need to jack up high enough to get the wheel off the ground (put a jack stand under the frame). If bad, replace with the heavy duty versions. Search this forum for "Radius arm bushings" to learn how to replace without cutting or drilling the rivits. Worn radius arm and/or pivot bushings can affect caster, camber and toe settings.
