Oil Leak
Old Dec 14, 2005 | 05:35 PM
trakman's Avatar
trakman
Oil Leak
My 03 with 70k has a rear main leaking. This one should be covered under warrenty right, with the $100 deductable? I'm one that doesn't like to have things wrenched but know it will take some wrenching on this repair. What all is involved in this repair and just how deep does the dealership mechanic have to go to get to the problem? I assume that the pan comes off and do they have to remove the automatic transmission? Thanks
Old Dec 14, 2005 | 07:56 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Tranny has to come out. Oil pan stays on. It's a one piece seal that bolts in place.
You're sure that's it's not a leak on the top side thats running down the back?
Old Dec 14, 2005 | 08:00 PM
bilder12's Avatar
bilder12
I would look reaaaaaaaal close at the top side first. turbo pedastal, hpop lines or rear head plugs for oil galley
Old Dec 14, 2005 | 08:01 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yeah, i would check the top of the engine, to see if the valley has oil in it. if oil is running down the back of the engine, down the bellhousing of the transmission, and dripping off the oil pan/weep hole, it is probably the turbo pedestal o-rings. i would check there before you get too hyped up on a rear main leak. they arent common.
Old Dec 14, 2005 | 09:46 PM
BadFord99's Avatar
BadFord99
My truck developed an oil leak, dripped of the inspection cover as well. Ended up being a bad o-ring on the oil rail plug on the front side of the passenger head.
I definately agree with these guys about checking every other possible source of an oil leak before tearing into it.
Old Dec 14, 2005 | 10:12 PM
andy351's Avatar
andy351
My leak just turned out to be the oring on one of my high pressure oil lines but I started out thinking the rear mainwas leaking
Old Dec 14, 2005 | 10:56 PM
hanklin's Avatar
hanklin
I have to agree, but also check oil galley plugs on rear side of heads,mine on passenger side leaked 2 days ago
Hanklin
Old Dec 15, 2005 | 02:59 AM
trakman's Avatar
trakman
Thanks guys....looks like maybe I was headed into the wrong area. I will check it out. All I know is it's not gettin any better and leaving an oil spot on the garage floor now! Did I fail to mention, I do not like oil leaks !!!!!! A big THANKS to all of you.
Old Dec 19, 2005 | 04:59 PM
F3504ME's Avatar
F3504ME
Mine is in the shop at this very moment for the exact same thing....
Mine only has 26k on it....
They are doing the dye test to find out where the leak is coming from....
Old Dec 21, 2005 | 01:38 PM
damone's Avatar
damone
Either Turbo boots or O rings could be the culprit. Try tightening the clamps on the Turbo Boots. That was what my problem was. easy fix. Now I check them periodically to make sure no leaky.
Old Dec 21, 2005 | 01:42 PM
F3504ME's Avatar
F3504ME
Yup...Mine is in for the CCV hoses,saturated and leaking....
Just where exactly is all that oil supposed to really go???
Intake???
