360 and 390 Differences
Old Jan 4, 2002 | 12:00 PM
bluemustang's Avatar
bluemustang
Can some tell me the difference between the two like HP, Torq and which is better, gas milage betwwen the two, any thing.
Thanks David
Old Jan 4, 2002 | 03:08 PM
buzzard's Avatar
buzzard
390 typically had about 40 more HP and 50 or so more lb/ft torque. Gas mileage should be about the same, although some say the 360 gets much worse.
Old Jan 4, 2002 | 04:33 PM
bluemustang
To go from a 360 to a 390 is there anything that has to be done or is the out side the same size as the 360? Will the same intake, valve covers, oil pan and etc fit on a 390?
Old Jan 4, 2002 | 05:15 PM
Ratsmoker's Avatar
Ratsmoker
Absolutely, the 360 and the 390 sometimes used the same exact heads and always had the same oil pan. The ONLY difference in the 2bbl truck versions of the 360/390 is the crank, rods and pistons. Air cleaners just had different stickers.
Old Jan 4, 2002 | 05:18 PM
jowilker's Avatar
jowilker
David, The crank and piston set is the only difference in the two engines. The 360 is a destroked 390. If you are thinking about a rebuild build it back as a 390, you will not be disappointed.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 4, 2002 | 05:30 PM
canzus's Avatar
canzus
The usual joke about the 360 is;
All the power of the FE352,
with the economy of the FE390.
Which isn't far from the truth...
Steve & the Rockette
Old Jan 4, 2002 | 07:26 PM
1ole4d's Avatar
1ole4d
