Aerostar Ford Aerostar
Bulb...
Old Dec 14, 2005 | 01:31 PM
maxwgn's Avatar
maxwgn
Bulb...
The little, 194 bulb that lights up the ATX floor shift indicator...HOW DO I CHANGE THIS BULB?
Old Dec 14, 2005 | 01:59 PM
ken1mod's Avatar
ken1mod
Easy, remove screws holding quadrant, bulb is underneath. easy 3 minute job including time to find screwdriver.
ken
Old Dec 14, 2005 | 02:54 PM
maxwgn's Avatar
maxwgn
Cool...thanks...hadn't had time to look at it, but wife's been complaining...
Old Dec 16, 2005 | 12:06 AM
Ed's Avatar
Ed
Mistake Here!!!!
ken
Ken, I think you made a mistake here. In order to change this #194 bulb, the transmission must be dropped. Next, loosen the LS (left side) motor mount. The RS (right side) motor mount must be completely removed. Tilt engine slightly. Driveshaft and U-Joint must be out also. Then, change #194 bulb. Installation, is the reverse of what I said. Ed (just kidding!!! ).
Old Dec 16, 2005 | 08:07 AM
ken1mod's Avatar
ken1mod
Dear Ed,
I was thinking about suggesting the factory method you suggest, but the home brew technique I USED SEEMED TO WORK. Not normal aero level of work, but what the heck. Thank the deity, this guy does not have awd.
Ken
Old Dec 16, 2005 | 01:07 PM
96_4wdr's Avatar
96_4wdr
may be easier to change wife than change that bulb in Aero....not as exciting or satisfying though
Old Dec 17, 2005 | 02:05 AM
Ed's Avatar
Ed
Talking
Yeah, but what if that "wife" looked like Pamela Anderson?? Huh? Then what? Ed
Old Dec 17, 2005 | 02:15 AM
Ed's Avatar
Ed
Dear Ed,
Ken
KEN, little did I realize my first post about dropping the trans, removing motor mounts, etc. is what the dealer Service Dept. will do to change the bulb! Of course you'll get the "revised work order" when you pick your vehicle up. Smelling salts sitting on the service cashier counter is cause for concern. Here's a tip: If the Ford Service Dept. Writer OWNS and DRIVES a brand new bright red w/ white stripe 2006 Ford GT-40, you might want to go elsewhere, especially if he is paid on strict commission for the service work he sells!...
Old Dec 17, 2005 | 10:28 AM
ken1mod's Avatar
ken1mod
My service advisor drives Mercedes sl500amg, Is that about the same?
Ken
