Steering swap
Old Jan 4, 2002 | 08:02 PM
AaronW's Avatar
AaronW
Steering swap
Ok I pick up the truck in the morning. I liked the manual brakes but I think I would rather have power steering. To swap from a 72F100 360 auto to a 69 F250 360 manual I need the column, pump, pump mount, lines, and gear, nothing else? Will the gear mount in the same spot or will it need modification?
Thanks
Aaron
Old Jan 5, 2002 | 07:35 AM
jowilker's Avatar
jowilker
Steering swap
Aaron, NOTICE! You will have a problem with the shifting of your manual tranny. About the only workaround is to go to floor shifting, find a rare SD ps column, or change your tranny to auto. Everything you mentioned will bolt right up. If you can grab the tranny and ds, you will be miles ahead, of course you might as well go for the discs too. :-)
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 5, 2002 | 09:27 AM
AaronW's Avatar
AaronW
Steering swap
Let me clarify, I own both trucks, the 72 F100 is not driveable. The 69 F250 is the one I will convert. It is 4 on the floor, the column should work just fine, since I will use and automatic column. Shift linkage should not be an issue? Do I have to swap engine mounts? Both trucks have 4 wheel drums.
Thanks
Aaron
Old Jan 5, 2002 | 11:30 AM
fomocoloco's Avatar
fomocoloco
Steering swap
i keep reading that these power steering columns with standard shifts are illusive. i have a 71 column and a 78 column fyi. thanks. jim.
Old Jan 5, 2002 | 05:23 PM
jowilker's Avatar
jowilker
Steering swap
Yes Aaron, you will need to swap the left engine perch along with the ps gear. You can get by with just swapping the column shaft if you want, now wireing changes, or you can swap the complete column and adjust the wiring as necessery. With Floor shifting already it looks to me to be a piece of cake.
John
jowilker email me
Old Jan 5, 2002 | 06:49 PM
Ratsmoker's Avatar
Ratsmoker
Steering swap
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
WazzuDMax
May 26, 2009 08:34 PM
engineguy33
Nov 23, 2006 06:39 PM
stanky
Engine Swaps
May 16, 2004 07:11 AM
AaronW
Feb 24, 2002 06:25 PM
