88 Running problem
Old Dec 14, 2005 | 04:27 AM
Gameover88's Avatar
Gameover88
88 Running problem
ok i have a 88 f-150 4.9 I6
when the engine is cold is starts fine and doesnt lope or want to stall but
after its warm and i shut it off and try to restart it
it sputters and wants to kill until i give it gas then its fine
any thoughts?
i was think its probbaly Ignition Related
i have a new control module installed just for the record
thanks
Mark
Old Dec 14, 2005 | 07:36 AM
subford's Avatar
subford
Pull your codes and if your codes are OK then change your Engine Coolant Temperature Sensor (ETC). The one with two wires plugging into it.
Old Dec 16, 2005 | 04:32 AM
Gameover88's Avatar
Gameover88
how would i check the codes?
do i need an actual scanner to do so?
Old Dec 16, 2005 | 06:50 AM
subford's Avatar
subford
Go Here:
http://fordfuelinjection.com/?p=13
No you do not need a scanner.
