Throttle Body Spacer does it help
Old Dec 13, 2005 | 10:32 PM
coreyl302's Avatar
coreyl302
Throttle Body Spacer does it help ????
i am just starting to put mods on my 1991 f 150 and i would like to know does a throttle body spacer really do anything for me and if so what does it help me with hp mpg anything
help me out....thanks
Old Dec 13, 2005 | 10:47 PM
frederic's Avatar
frederic
I had access to an engine dyno a while back, and did a variety of testing of various things. One of those things included three different brands of throttle body spacers. None of them did anything other than to move the throttle body away from the plenum. There were no gains that we could see.
Old Dec 14, 2005 | 12:11 AM
Twitche's Avatar
Twitche
nothing I have ever heard says that throttle body spacers work. Theoreticly, it give the throttle body more space to atomize the gas vapors but the change would be unfelt. Stay away from the Tornado. It spis incoming air but creates too much turbulence. The turbulence actually slows air, not increases it. It lowers mpg and horspower, Not good at all.
Old Dec 14, 2005 | 01:37 AM
MemOrex's Avatar
MemOrex
Throttle spacers are no good, but I've heard that heat spacers (manifold spacers) can help since the make the runners a little longer.
Old Dec 14, 2005 | 09:33 AM
coreyl302's Avatar
coreyl302
thanks
thanks for the help
Old Dec 14, 2005 | 01:08 PM
EPNCSU2006's Avatar
EPNCSU2006
Originally Posted by Twitche
Theoreticly, it give the throttle body more space to atomize the gas vapors but the change would be unfelt. Stay away from the Tornado. It spis incoming air but creates too much turbulence. The turbulence actually slows air, not increases it. It lowers mpg and horspower.
The throttle body doesn't atomize anything; that's the job of the injectors. And theoretically, turbulence helps evaporization of liquid fuel droplets, which helps power and fuel economy. This is more of an issue on carbureted engines. Fuel injectors already do a pretty good job of atomizing the fuel for easier evaporation and combustion. Don't get me wrong, I'm not saying either the spacer or tornado do anything.
54F350LNB
47
Aug 6, 2019 12:59 PM
rockher_man
Ford Truck Parts for Sale
Sep 12, 2012 10:29 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
gehrig
13
Aug 1, 2005 08:28 PM
