Head work on 5.8
Old Dec 13, 2005 | 09:29 AM
osborn's Avatar
osborn
Head work on 5.8
I was wondering if anyone knew the flat rate labor, in hours, to remove and replace cylinder heads on a 1995 f250 w/ 5.8. Thank you in advance.
Old Dec 13, 2005 | 10:31 PM
1997 F350's Avatar
1997 F350
I just did mine and it took me about 10 hours or so.I was in no rush as I had a another car to drive.It will most likely cost between 1000-1200 when all is said an done between the parts and labor.Possibly more if there are issuse with the heads.It is not a hard job except dealing with the rust on the exhaust and emmission pipes.
Old Dec 14, 2005 | 02:24 PM
osborn's Avatar
osborn
Thank you for your response.
Old Dec 14, 2005 | 02:26 PM
ford390gashog's Avatar
ford390gashog
yes about 1200.00 plus parts. which is a easy 400.00 a head. you will be oover the cost of a new engine.
