Electromagnetic Brake
Old Dec 19, 2005 | 03:48 PM
Hamberger's Avatar
Hamberger
I agree with you, the next project will be the ZF5, the turbo will have to wait. More bang for the buck with the tranny than what a turbo would ever give me.
Note, I did get a quote for a ZF6 (early version, no polished gears) for only about $300 more than the ZF5, although the cost would probably be in trying to make it fit with my T.C. or the cost of a new T.C., shaft mods,,,,,etc....
If I am going to buy a donor truck I probably would consider rebuilding the a ZF5 myself to save some $$$. Depends on the shape of the core I guess. I heard some horror stories of ZF5 with cracked casings (due to abuse no-doubt).
I also like your note on the Synthetic ATF, I actually added some Duralube Tranny additive awhile ago to both the tranny and the transfer case on my 93.
I have used the Duralube in my turbo diesel engine since I bought the truck in 93 and it has kept it as clean as a whistle and does not use a drop of oil after 210,000 km's
Old Dec 19, 2005 | 07:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The ZF 6 would need the transfer case that was behind the ZF 6 originally.
NP 283 if I remember right.
The BW 1356 transfer case you have now would not fit, input shaft is way to small.
The swap is not that big a deal, well since you have an automatic it will take some work with the pedals.
You will have the same thing with any manual though.
What is a deal is you have no speedometer.
The trucks that had the ZF 6 had the speedo pickup in the rear axle.
Old Dec 19, 2005 | 07:22 PM
Hamberger's Avatar
Hamberger
Good point on the tach with the ZF6, that in itself is enough argument to stay with the ZF5 for sure.
Bubbatruck
29
Aug 31, 2016 11:56 PM
h82loseejr
Feb 13, 2016 12:43 AM
jayro88
Dec 20, 2015 07:42 PM
wdhille
Jun 14, 2011 09:56 PM
RomerB2
Sep 14, 2005 07:12 PM
