O2 sensor heater circuit
Old Dec 23, 2005 | 08:23 PM
  #31
Popa Tim's Avatar
Popa Tim
it sure does...LOL
Old Dec 23, 2005 | 10:48 PM
  #32
dalepr's Avatar
dalepr
I got the truck back from Ford today. New ECM installed and have about 100 miles on it with no light. Seems to be fixed. Thanks everyone for the input.
Old Dec 24, 2005 | 10:49 PM
  #33
Roushians's Avatar
Roushians
cool man, good to hear
Old Dec 24, 2005 | 11:10 PM
  #34
broken wire's Avatar
broken wire
I'm going to chime in here, Fuel pressure on this 1996 engine is 45-60 PSI key on engine running, closer to 45 with vacuum on the fuel regulator, and closer to 60 with the vacuum line off the fuel regulator running. 50-60 key on engine off.
P0136 says HO2S-12 no activity circuit conditions: Engine running in closed loop for 5 minutes, then the PCM detected that the HO2s failed the maximum or minimum voltage range check (middle signal out-of-range)(which means: oxygen sensor is not crossing the 450 millivolt range) note which oxygen sensor here that code 136 is talking about, the sensor behind the catalytic converter, not in the exhaust manifold. This is not a heater circuit issue, but a oxygen sensor performance issue, could be staying high, above the 450 millivolt range or it could be low, under the 450 millivolt range, the sensor performance is just not crossing the middle of the sensor calibration area. I would backprobe the sensor wire and test the sensor or remove the sensor, mount the sensor in a bench vice lightly, hookup the meter to the sensor and send a propane torch lightly over the sensor and check the ability to cross the 450 millivolt range consitently for starters. If the sensor works, check wiring to PCM, backprobe PCM wiring at PCM, retest O2 performance, if O2 is not working, replace O2.
Hope this helps, broken wire
Old Dec 25, 2005 | 11:23 AM
  #35
Roushians's Avatar
Roushians
broken wire: whoa. best answer ever. thank you
ojh
28
Aug 3, 2016 02:51 PM
tahiti429
1983 - 2012 Ranger & B-Series
May 5, 2011 06:32 PM
terrysumner
Jan 19, 2011 09:21 AM
Adamjr
Jun 12, 2010 09:45 AM
Jimmat
Electrical Systems/Wiring
Sep 2, 2003 05:46 PM
