First question post. The door tag? '63
Old Dec 12, 2005 | 03:09 PM
cougardan's Avatar
cougardan
Looks like the original paint is missing so maybe someone can tell me what the different codes represent. Looks like it was originally beige or white. Do I need to see the diff. tag for the rear gear?
Thanks, Dan
F10CR372461
122 M F100 81B B 12
5000 135 3800 71
Old Dec 12, 2005 | 07:12 PM
BobbyFord's Avatar
BobbyFord
F10 = 61-66 F100
C = 61-64 292 cid 4 barrel 153 h.p. @ 3800 rpm
R = San Jose, CA plant
372461 = Jan. '63 birthdate
122 = wheelbase in inches
M = Corinthian White
F100 = Model
81B = 61-66 Custom Cab
B = 61-65 3 speed overdrive trans.
12 = 3.89:1, 9" rear end
5000 = Max GVW (Gross vehicle weight)
135 = H.P.
3800 = Max H.P. rpm
71 = Los Angeles D.S.O.
Welcome to the site.
There's more info here than you can shake a stick at.
Old Dec 13, 2005 | 05:53 AM
jowilker's Avatar
jowilker
Thanks, Dan
F10CR372461
122 M F100 81B B 12
5000 135 3800 71
Dan, Welcome to FTE The best Ford truck show on earth!
Hope you find that info helpful.
John
Old Dec 13, 2005 | 08:36 AM
cougardan's Avatar
cougardan
Yep John, that decode info is great. I may have to pull that rear gear for a hot rod project I have. Maybe put a 3:25 or so there. The original motor is long gone. A 360 with C-6 has been swapped in with the column shift.\
Don't think it'll end up white either. Looks like some turquoise green has been rolled and brushed on. Don't like the finish but the color is growing on me.
I got the bed pulled yesterday morning- with a tip I picked up on the site. I cut the bolt heads off instead of fighting them from below. Figure some new bolts will be worth the price.
Now I have access to the frame and driveshaft repairs. Also with the axle flipped on the springs, the shocks look way too flat to me. May have to lower the axle mounts some. Probably have the rear frame and axle blasted while it's apart. Maybe I'll use some Hammertone paint on those. Sure like the look.
I'll post some pics when I figure out where to upload them.
Thanks, Dan
