Now im really confused..
Old Dec 15, 2005 | 07:41 PM
fonefiddy's Avatar
fonefiddy
issit cranking fast enough? I've fired my 6.9 in -20F weather with no starting aids. It sure didn't sound pretty, but it fired up.
Old Dec 15, 2005 | 07:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Go to the glow plug relay and follow the two orange wires with the white stripe.
Near the oil dip stick they go into a connector where the truck harness connects to the engine harness.
Try unplugging the connector and examine it for signs of overheating.
I had a problem like this with mine several years ago.
The connector had overheated and deformed to the point the wires were not making contact well enough to heat the glow plugs.
I had to cut the orange wires on both sides of that connector and splice them back together so they made good contact.
Also have you checked for voltage at the relay and at the glow plug connectors when the button is pushed?
The glow plugs could be in great shape, but if the power is not reaching them they won't work.
Old Dec 16, 2005 | 01:48 PM
GiS's Avatar
GiS
Thanks for the idea Dave, I took this picture....Looks to be ok but I will take it apart and inspect it further.
Dave, what do you mean by voltage relay? The test I did was this: I put my test lamp on the female connector that attaches to the GP, then had my GF hit the GP button, the light came on...so I think power is getting to the GPs...I will still check the orange wires.
fone, it sounds like its cranking fast enough, just not catching or firing. Doesnt sound slow or drained by any means.
bigred, I am going to try and stop by a parts store and get a free battery test. The two batts in the truck are the 1000 cca but I have no idea their age. Will check them out.
Thanks for the ideas guys!! Have been leaving it plugged in now just so it will start but would like to be able to start it without being plugged in someday.
-Joe
Old Dec 16, 2005 | 09:51 PM
Dave Sponaugle
You already answered the question about voltage going through the relay and to the plugs.
The connector does not look deformed, that is the right one. Check for corrosion inside the connector though.
When you have the batteries load tested you must disconnect the ground from the battery you are testing to get a good test. Otherwise you are drawing current from two batteries and even bad ones will look OK to the machine.
Old Dec 19, 2005 | 09:33 AM
GiS's Avatar
GiS
Thanks for the heads-up on the battery and ground...I will have to re-test them now hehe.
Dave, without you on this site, alot of us would be lost
-Joe
Old Dec 19, 2005 | 08:55 PM
Dave Sponaugle
Thanks for the kind words.
But do you know who you are tructing with your truck?
I might be a real joker....
Old Dec 19, 2005 | 09:17 PM
pnose's Avatar
pnose
OMG,didnt i see you at the mall yesterday,lol.
Old Dec 19, 2005 | 10:37 PM
Dave Sponaugle
If you were home I hope not.
I have been feeling kinda out of it though.
Maybe I am really out of my body...
Old Dec 20, 2005 | 02:09 PM
GiS's Avatar
GiS
LOL! Its been too cold to go tinker on the truck..I could of used a hat like yours yesterday to keep me warm
Too funny dave!!
-Joe
Old Dec 20, 2005 | 06:13 PM
Dave Sponaugle
That is my snow plow hat.
When you spend hours shoveling out the driveway, as soon as you put the shovel away some joker in a snow plow comes by and plows it shut again.
At least I do look the part when I am plowing since I have the correct headwear.
lalh20
30
Feb 19, 2014 07:14 PM
1L243
Nov 23, 2013 11:04 PM
Baddhabit
Jan 7, 2013 09:25 PM
j tate
Dec 23, 2008 11:47 PM
Glockem45
33
Nov 10, 2008 08:34 PM
