Sponsored by: Kumho
Steering, rag joint?
Old Dec 12, 2005 | 11:29 AM
78bigunns's Avatar
78bigunns
On my 79' F150, at the end of the steering shaft, it has a large metal piece, then a rubber piece, then it ties into the steering box with a couple bolts. At least that's what I remember it looking like.
Is this what is refered to as a rag joint?
To freshen this up to be safe, is there a specific part or something I can get?
Do I just need to put in a new rubber piece?
I'm trying to tighten up my steering some, when I jack up the truck and pull on the front wheels top to bottom and side to side, I get no movement. I figure this means my tierods and balljoints are holding good for now?
Many thanks for input or advise,
Blair
Old Dec 12, 2005 | 01:38 PM
bob arrington's Avatar
bob arrington
it is a rag joint and if its not broke it probably doesnt need to be foxed, bob
Old Dec 12, 2005 | 01:52 PM
78bigunns's Avatar
78bigunns
Nope, didn't appear to be broke. Just looked old as sh**.
Thought maybe it should be swapped out for new one.
Thanks!
Old Dec 12, 2005 | 02:02 PM
73Custom's Avatar
73Custom
They are cheap and pretty easy to replace. If it's old and rotted, might as well replace it. Most parts stores can get a new rubber disc for about $10.
Marty
Old Dec 12, 2005 | 04:12 PM
78bigunns's Avatar
78bigunns
Again, Thanks.
I'll give it a serious once over soon.
Old Dec 13, 2005 | 05:19 PM
bob arrington
those usually break when you kiss a curb to hard, if it looks old and frayed you could replace it just for good measure ,my 2c's, bob
Old Dec 13, 2005 | 06:00 PM
78bigunns's Avatar
78bigunns
I'll keep it in mind. I'm just starting to drive her more and more, thought maybe that was a area that could use a second once over.
Thanks
