head lights gone.....what happened????
Old Jan 8, 2002 | 05:47 PM
dablack's Avatar
dablack
I was driving to work this morning and all of a sudden bam! No head lights. I pulled of the well lit road and let it sit thinking I just over heated something. Well I let it sit for 10 minutes and still nothing. I turned on my brights and one of them worked. After work I went and got a new light and just put it in. Guess what no lights at all. No brights or anything. Everything else works great. All other lights work. What happened? Where do I go from here?
Austin
71 F100 SWB
Old Jan 8, 2002 | 05:56 PM
76RangerXLT's Avatar
76RangerXLT
sounds like you have a problem with the wiring to the lights... or maybe the switch is fryed. you should test connections and grounds with a volt meter
Old Jan 8, 2002 | 05:57 PM
Mil1ion's Avatar
Mil1ion
Either the Dimmer switch or the headlight switch.
The Dimmer switch is the cheapest replacement.
Headlights Don't have fuses,they have Circuit breakers.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 8, 2002 | 05:59 PM
Cowboy_351's Avatar
Cowboy_351
Make sure to check the connections to the back of the headlights too i had some that had rotted away due to moisture
1979 F-250 4x4 351M "Red Line"
Old Jan 9, 2002 | 02:35 PM
ktienken's Avatar
ktienken
Hi Austin: similar thing happened to me. Started the 81 courier and no lights. The fuses looked good but the ends were loose. Changed the fuses and wiggled the fuse box to see if a short was there and they have been working fine.
Keith
Old Jan 10, 2002 | 08:00 PM
Nod's Avatar
Nod
Austin, my 72 did the same thing, after hours of checking everything I found a dead short in the wiring harness where it crosses the battery box.All the vibration over the years had worn thru the wire insulation and the wire finally welded itself to the battery box.I taped it back up and cut a length of small hose that I slit the long way then taped it over the whole thing.That was years ago and no more light problems. Hope this helps.
"bowties in the rearview mirror"
Old Jan 11, 2002 | 09:51 AM
68FORD's Avatar
68FORD
Same thing happened to my 68 F-100. It turned out to be the dimmer switch.
Old Jan 11, 2002 | 11:15 AM
drjohn's Avatar
drjohn
