Yes, technically any electrical load will effect gas millage. Even though the alternator is always turning and likely always has some load on it, the more power it supplys, the harder the pully will be to turn on the alternator and therefore a load on your engine that will affect gas millage. In the real world I don't know if you would ever notice the difference. John
No, unless it is an accessory that it's a really heavy accessory or one that somehow puts a load on the drivetrain. Heated seats will not have any effect on gas mileage.
Well, actually, yes. Other than your starter, which is only used intermittently, your lights can be a nontrivial load. So during operations at night, the wattage for powering your lights has to come from somewhere, and that's the engine.
Yes, the alternator turns whether the lights are on or not, but when on, the alternator's field coil is energize to create a greater resistance to the motor. Now with a PSD it might not make much difference, but in a car, I've always heard that it costs you a mile or two, though I've never worked it out.
Anything that draws current makes the alternator harder for the engine to turn. The more the load, the more effort is required from the engine. Light loads like the dome lamp or radio have little effect, but heavy loads like the headlamps, hi speed blower, or heated seats will definately affect your gas mileage--maybe not by much, but some.
Look at it this way. 746 watts equals one horsepower. The output voltage of the alt is about 14.5 volts. That means that you would have to have a current draw of 51.4 amps to be losing one horsepower. So if you put a big load on the power supply you will have to use more fuel to take care of it. But you can also look at it that if running unloaded that it takes 100 HP (I just picked a number) that a 50 amp load would take add 1% more power so it should be very little extra fuel.
In other words, no, it won't impact your fuel milage.
but also realize how easy it is to draw 52 amps.
the heater motor draws 15 amps, headlights 15 to 20, heated seats 20 amps each, then you have the drwa of the engine and its systems. which add up to a constant 20 amps all the time of power use. so 90 amps. but still not a lot of HP loss
However, an alternator is not 100% efficient (no free lunch). An average OEM is roughly 50-60% efficient, and that fails to include the parasitic losses present in the belt/pulley system.
