Overdrive w/ 3.08's question
Well in a few weeks I am going to be pulling my motor for a rebuild, and Im getting a manual 3 speed w/ overdrive tranny to replace the C6, because I need something with overdrive for the highway. 2600 rpms (with a 4.9) @ 65 kills the gas gauge, it just seems to drop .
I am curious how the motor will act in overdrive with a 3.08 rear end, I dont want to put in the new tranny just to have my engine not have enough power to keep the truck moving on the highway in overdrive. Anyone think I'll be fine with that set up on the highway?
Also what rpms should I expect at 65? Any mild guesses will do fine.
Go here and put in your numbers. If you have tall tires, you are going to be in OD at 55+ only.
http://www.novak-adapt.com/knowledge/gearing.htm
