31-11.50-15
Old Dec 10, 2005 | 03:28 PM
walker_73's Avatar
walker_73
Arrow 31-11.50-15
i have a stock 1996 f-150 and want to run 31-11.50-15 super swamper LTB. is this possible without any rub?
Old Dec 10, 2005 | 04:48 PM
Mark Wenner's Avatar
Mark Wenner
From what I've read in these forums and elsewhere many folks report some rubbing on the radius arms even with 31x10.5s mounted on stock rims on a 4x2. Most would say you can go up to 32x11.5 on a 4x4 without significant rubbing, but what's significant is subject to interpretation and how you intend to use the truck.
Old Dec 11, 2005 | 05:26 AM
Oval_obsessed's Avatar
Oval_obsessed
I've had 32-11.50s on my '94 f150 4x4 and they were fine. I think the key to reducing rub would be to watch the backspacing and width of the rim that you decide to go with.
Old Dec 11, 2005 | 07:58 AM
Thomasm67's Avatar
Thomasm67
I run 31/10.50/15's on my 87 F150 4x4 and there is no rubbing at all i know a few people who have 33's and had no problems with rubbin. As Oval_obsessed pointed it has alot to do with backspacing. If you used 15x8 you shouldn't have a problem with rub.
Old Dec 11, 2005 | 08:04 AM
mikeyswood's Avatar
mikeyswood
I believe that 4x4's have a 2" body lift as well as a higher suspension. If you are in a 4x4, 31's should be fine, but if you are running a 4x2, you will want a 2.5" suspension lift for alignment issues.
Good luck and do your homework,
Mike
Old Dec 11, 2005 | 02:08 PM
boatbuilder's Avatar
boatbuilder
I have a 92 4x4 with 33/12.50/15 and have no rubbing probs, but have had some power sterring probs.
Old Dec 14, 2005 | 03:44 PM
walker_73's Avatar
walker_73
i put the tires on and they are fine.they rub the radius arm a little bit but it had no effect on the turning radius. thanks
