Diesel Fuel
Old Dec 10, 2005 | 03:02 PM
flyguy2's Avatar
flyguy2
Diesel Fuel
A friend has told me that it is OK to use semi-tractor fuel in a 6.0 PSD. He says that he uses it when the temperature gets really cold because of the additives that are in it. Is this true and is it a good idea?
I also wanted to let everyone who has been so helpfull sharing information about diesel engines. I've decided to get an '06 F-250 with a 6.0 PSD. It will arrive here in Flagstaff the week between X-mas and New year. I'm Looking forward to many new adventures with more than enogh power.
Thanks Again
Flyguy
Old Dec 10, 2005 | 03:15 PM
kw5413's Avatar
kw5413
It is the same. There is no distinction between the two.
In cold weather most recommend anti-gel fuel additive such a Fords additive, PowerService (while bottle), or Stanadyne.
No offense to you or your friend but, I would seek out someone with a little more knowledge for diesel advice.
Congratulations on your new truck. Read as much as you can here at FTE and you will learn much.
Safe trucking.
Old Dec 10, 2005 | 11:12 PM
tn mac's Avatar
tn mac
wHAT your friend is talking about is #1 diesel which is used in the colder areas, and as KW said use a good fuel additive, good luck with the new truck.
Old Dec 11, 2005 | 04:11 PM
Drone Leader's Avatar
Drone Leader
Not sure if your friend knew this or not; but 'truck stop' diesel typically doesn't sit around in the station's underground storage tanks as long as your neighborhood station does. Less opportunity for water, algee, and other bad things to happen. And the prices tend to be lower too - I've seen 60 cents per gallon difference between the Conoco three blocks from my house or the truck stop 13 miles from my house. And I wonder how empty the Conoco storage tank will need to be before they fill it with the 'winter grade' diesel.
Old Dec 12, 2005 | 05:18 AM
Crash687's Avatar
Crash687
you live in AZ, how cold can it really get? the local truck stop probably sells winter blend for truckers that have to venture to north where really gets cold
JiminCA
Jul 8, 2013 01:28 PM
Doug C.
Arizona Chapter
Nov 26, 2012 11:10 AM
flyguy2
1983 - 2012 Ranger & B-Series
25
Jun 2, 2009 05:42 AM
flyguy2
27
Apr 6, 2009 10:15 AM
flyguy2
1997 - 2003 F150
Feb 10, 2005 05:05 PM
