Steering shaft u-joint replacement:
Old Jan 10, 2002 | 05:41 PM
79Supercab's Avatar
79Supercab
I need to replace my upper u-joint in my steering shaft on my '78 F250 4x4. It is the one with the small u-joint that is connected to the shaft coming out of the column.
I know that JBG sells them, but they are a fortune. I would rather find a new u-joint assembly, cut off the old u-joint assembly, then weld the new one on the end of my shaft.
Where can I just get the u-joint assembly besides the junkyard?
Ryan.
78 F250 Ranger XLT Supercab 4x4
460, C6, NP205, D44, D60, 4.10's, 33x12.50x16.5 tires
71 Bronco, 302, C4, PS, PDB (1/2 complete with rebuild)
Old Jan 10, 2002 | 07:23 PM
tongie607's Avatar
tongie607
Bad idea welding on steering assemblies! LMC has new ones but your right they are pricey $299 for the entire assembly. I once made new bushings for the U joint from copper pipe, probably not very safe either, but it worked real nice.
Old Jan 10, 2002 | 07:30 PM
tongie607's Avatar
tongie607
you know what ? I'm an idiot after that last post I remembiered all my hot rod stuff and just happened to look in my Summit racing catalog.
64.95 made by flamming River if you dont have a summit catalog let me know and I'll post the part numbers
Old Jan 11, 2002 | 07:34 PM
coffmans's Avatar
coffmans
How about posting those numbers?
I need a new u-joint and dont have a current catalog
how about a web address?
Larry
Old Jan 11, 2002 | 08:20 PM
tongie607's Avatar
tongie607
FLA-FR1702 3/4 x 3/4-36-sline $64.95 that one is listed for 76 and up power steering. You can find more at Summitracing.com
Old Jan 13, 2002 | 03:05 PM
Mil1ion's Avatar
Mil1ion
Old Jan 14, 2002 | 08:39 PM
coffmans's Avatar
coffmans
thanks,I`ll have to get that ordered
Larry
