May it be assumed that the bleeding was started at the brake furthest from the MC and worked closer. I know it may sound like an elementary question but I've caught myself starting at the wheel I was closest to rather than the one farthest from the MC.
I only changed 2, and I started with the rear, and I didn't pull the pin on the portioning valve( I thought I needed to, but it had a heavy constant stream coming out, and that is what I heard is all you needed).
If any of this is wrong, please let me know. Also, I'm not even sure where the pin was to pull on the valve?
