Sponsored by: Auxito
Cold Weather/OBDII
Old Dec 9, 2005 | 04:41 PM
Donnie Askew's Avatar
Donnie Askew
Cold Weather/OBDII
My 2001 F150 set for two days in 10-25 degree weather. When I drove it to work the sevice engine light came on after two or three miles. Could this be a result of the cold weather and it will reset on its own or should I have something to worry about. I have had only one cold start since it first appeared and have not had a chance to pull the code or reset it.
Old Dec 9, 2005 | 04:44 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
I would scan it. If you don't have a scanner, Autozone will scan it for free. Let us know what codes you get and we'll go from there.
Jimmy
Old Dec 13, 2005 | 03:44 PM
Donnie Askew
P0174
I just got to read the code for my SERVICE ENGINE light that popped up during a cold spell last week. It was P0174 "System too lean, Bank 2". could this have been caused by my 2001 F150 being parked for two days in very cold weather. I cleared the code to see if it will come back.
Old Dec 13, 2005 | 08:53 PM
LxMan1's Avatar
LxMan1
Possible. It could also be a dirty MAF or possible vacuum leak at one of the PCV hose elbows. These usually throw codes for both banks being lean though. I'd wait and see if it comes back again.
Old Dec 13, 2005 | 09:01 PM
flatrate's Avatar
flatrate
id look for a vac leak on the drivers side....even stupid stuff like the oil dipstick not fully seated can cause "unmetered air" entering the engine and cause lean codes. sounds stupid, but i have seen it.
Old Dec 14, 2005 | 11:34 AM
projectSHO89's Avatar
projectSHO89
Cold weathermakes everything shrink. This causes old gaskets that used to seal all the time to develop cracks or gaps that allow vacuum leaks.
Chances are, if left unfixed, the problem won't restrict itself to just cold weather.
Steve
Old Dec 16, 2005 | 02:55 PM
Donnie Askew
P0174 Gone
Since clearing the P0174 code, I have put over 300 miles on the truck and no problems. We have had several nights with the temp in the mid 20's and so far so good. I'm going to wait and see if it returns with the next real cold snap, before I start looking deeper. Thanks for all the suggestions and help.
