it is called axle wrap, look on google for a good explanation definition. Typically, this can be solved with a good oil shock or anit wheel hop bars. It is unlikely that this can be solved on a real big rig
Thanks CG, i figured it was a weight issue, jus had to make sure, my shocks are stock theyre rough as hell on the road, probably looking to upgrade but ima a power freak so if i get the money for shocks ill swap but right now i want exhaust and a turbo
Its a diesel truck, why on earth would you want to do a burnout in it. Buy fox body mustang beater, and abuse it with a nice smoky burnout just my $.02
my 89 F250 will burn pretty good with no wheel hop, in first gear. For real fun, I take the Cobra convertibe out for a run. That will still loose control in 2nd and 3rd gear. Ask me, I have done it....
Put some donut tires on it and that diesel should burn rubber without even trying.
I would take off real fast when it was raining and the 33" BFGs would lose traction and start hopping and it broke all the springs in my clutch.
Traction bars would help I would think.
