Battery Replacement
Old Dec 9, 2005 | 12:03 PM
jlpmba's Avatar
jlpmba
Battery Replacement
I'm afraid the juice has ran out of ye old batts.
Looking for replacements, anyone have advice to
replace with and whcih ones to run away from?
Thanks.
Old Dec 9, 2005 | 03:15 PM
BajaGringo's Avatar
BajaGringo
I am using Exide AGM Spiral Wound batts. I've also used the Optima. They're more expensive than most other liquid acid but the terminals NEVER corrode and I never need to worry about adding water. Get 1000 CA ones whichever you get. At lot of us use the Wal-Mart brand.
Old Dec 9, 2005 | 04:07 PM
tjc transport's Avatar
tjc transport
i ain't rite
i get the batterys for my 88 from napa. i am now on my third set, they are less than 1 year old. got 3 years from the ford batterys, and 7 from both of the napa's
Old Dec 10, 2005 | 10:24 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I use the Duralast Gold from Autozone. They have the bast warranty I could find and were also the least expensive 1000ca (850cca) battery out there.
Old Dec 10, 2005 | 01:54 PM
yardboy's Avatar
yardboy
Make sure your starter isn't worn out. I replaced alot, but finally figured out it was the starter. It was only acouople of years old so I didn't think that woould be my problem. MISTAKE! Good luck.
Old Dec 11, 2005 | 07:17 AM
Saigon's Avatar
Saigon
I use the biggest "boat" batteries that will fit,can't afford to have dead batteries on the open sea!!!!They will hold the charge better and longer!
saigon
Old Dec 11, 2005 | 08:40 AM
Chevy_Eater's Avatar
Chevy_Eater
Yeah, I did the same thing with my '84 a few years back. Bought teo new batteries I didn't need.
FWIW I use Die Hard Gold. Tough batteries with lots of cranking amps. Sears "customer service" leaves much to be desired, but good battery all the same.
Old Dec 11, 2005 | 07:34 PM
IHdieselfan's Avatar
IHdieselfan
I use carquest batts. there made by deka. i've had the set in my '87 for 8 years, best i've ever got out of a set. I like interstate too.
Old Dec 12, 2005 | 12:12 PM
jlpmba's Avatar
jlpmba
Thanks all for the info, went with the duralast gold was $160 out the door and came with a jump start card for 3 years if needed, should I be worried?.
However, noticed that the alternator belt "flaps" wildly. Went and pulled more tension on it and same thing?
Is this good, I don't remember it doing this before. It is a new belt with ribs on top, changed a few months ago while doing the water pump.
Thanks again!
Old Dec 12, 2005 | 12:37 PM
smiller4597's Avatar
smiller4597
my alt. belt flaps wildly also. could never get the flap out. I think it is just too long of a run for the belt. I have never had any problems with it just looks like it is not right.
Old Dec 12, 2005 | 01:40 PM
Chevy_Eater
That's the way they all are, 6.9 and 7.3. Don't worry about it.
